1 - 9 of 9 Posts
I apologize in advance if I missed a thread about this but... I recently installed coilovers and am having a clicking sound when turning. It seems to be coming from the inside wheel of the turn and its just one click that happens near full lock. I've only tested it at low speeds because I don't really have access to anywhere that I can test a high speed full lock turn.
Super Moderator
Is it the CV? You can check the top bolts, camber plates, spring seat. What coilovers and what setup?
Honestly if it's at or near lock I suspect CV first.
Discussion Starter · #7 ·
Can it? Yes. Did it? Don't know anything about your vehicle to say.
Check all the things i listed
OK, I've buttoned up everything, check the spacers and tightness of everything, including the bolts for the coilovers and I'm still getting the sound. HOWEVER, I realized that I misdiagnosed it earlier. Its not a clicking, I'd call it more of a creaking noise and it'll happen when turning right (almost full lock) or under moderate braking. I feel fairly certain that it has to do with the spring but not sure.
Discussion Starter · #9 ·
Spring seat?
I mean it looks fine, its resting evenly. One thing I did notice while the car was on the ground is it appears to be sitting a little higher on the passenger side front and rear ( about 1/4" in rear and 1/8" in front) could it be that its preloaded wrong? I had just assumed they would be good from factory.
1 - 9 of 9 Posts
