1 - 2 of 2 Posts
Hello everyone my name is José I’m Washington state and I’m about install my access-port on my 2014 wrx but the issue. I’m running is what stage should I run with the mods I currently have on the engine are Cobb instake, invidia castlesa down pipe, hks uppipe, mitshimoto top mount and a gfb Tms response blow off valve,
Go to Cobb's site and peruse the map notes. Load only that map that lists specifically your components.
If you cannot find a map that lists your components, you will either need a custom map or you will have to leave off that particular component.
1 - 2 of 2 Posts
