1 - 4 of 4 Posts
I was wondering if anybody else did what I did and now can't figure out what map to use. I have a 09 wrx with an after market downpipe, cat back exhaust, and a stock air box with a Hks panel filter and cold air snorkel.
My question is do I use the stage 2 map or stage 2 plus? Or do I use stage 2 with the lower waste gate duty cycle?
Thank you.
Lando Calrissian
ok, so you have a custom TBE and a stock airbox....that would be the stage 2 OTS map.
If you went with a full CAI, you would need to look at the stage 2 +, but only if the CAI was one that Cobb tuned for....if for instance you got an HKS cold air intake, you would not want to use the stage 2 + AEM
Stage 2 map. After logging if you see your boost isn't what cobb says it should be, you may need to use the lwg or hwg maps.
1 - 4 of 4 Posts
