Installed my Cobb SF Intake and Stage 1 map (normal) with the AP. Noticed immediately that the rpm's like to stay around 1500 rpms at idle for about 5 minutes and then go back to normal. Thought that was weird. However, what bothered me more is that throttle sensitvity was alot lower. Meaning I had to press on the gas more to actually move the throttle body and raise the rpms. Very annoying. Most aftermarket tunes increase sensitivity, not lower it. Anyone else notice this?
I even monitied the TPS with the AP and confirmed I could move the pedal about a 1/4 of an inch before a voltage change was recorded. When stock, Even the slightest movement of the pedal increased rpms.
