1 - 9 of 9 Posts
Just received my Cobb for my 2012 wrx.
I have Invidia catless downpipe stock exhaust and
A AEM intake.Wondering which stage and map to
Use
That's what map notes are for - they tell you what modifications you need to run the map ;)
StageII+AEM would be the closest match
Thanks for your reply. Chech engine,traction
Control and cruise lights should go out after I
Install Cobb?
Stage2+Intake 93 MTv310- Intended for 2012 Subaru Impreza WRX vehicles with AEM Cold Air Cold Air Intake
System, and a turbo-back exhaust system with high-flow catalytic converter. 93 or 94 octane fuels. Boost
Targets: ~18.5psi peak boost pressure tapering down to ~13.5psi by the 7000 RPM redline, +/- 1psi.
Control and cruise lights should go out after I Install Cobb?
You have a CEL?
Thanks for reply.thatsp you gave me is in access port
Already or do I have to download it? Yes I have Check Engine Light
What code (P####)?
so are you just ignoreing your cel? are you hopeing the AP will make your problems mysteriously vanish? It could be that your running a catless dp...
1 - 9 of 9 Posts
