1 - 2 of 2 Posts
I was pretty sure that my clutch was toast but now its acting normal...
It was slipping at 75% -Wide open throttle when above 5psi. If i got off the accelerator and got back on it the clutch would grab.
Now it seems to be fine. I'm starting to think that the slave cylinder is going. There are no apparent leaks for the slave.
Any help or ideas would be greatly appreciated.
FYI: I have a 2007 WRX TR
Check for air in the line . Bleed your clutch and see if that helps any . Got enough fluid ? You said its not leaking but u never know it may need some fluid. Start with the simple things before trying the cylinders .
1 - 2 of 2 Posts
