1 - 6 of 6 Posts
So I decided to go forth and try an fix the clock on my 02 WRX (because it's a widely known problem). I managed to get the housing off and the clock out. I'm currently working on fixing the connections before snapping it back together.
However, I began to wonder if there was a clock they made to go into the triple gauge cluster that would go in place of the clock. This way I could have a clock in one of the holes and simply cap off the other two until I decide to hook something up to them.
Does anybody know of such a clock? :confused: Would it be able to be simply reconnected to the original wiring and connector for the original clock? Thanks.
your going to have to do some wiring. It should be very simple but you will have a hell of a time getting a gauge that uses the stock wrx plug. If you want I can sell you a working stock clock for cheap.
You're welcome, and there are all sorts of options out there as far as color, digital/analog style, so you can really customize to your liking.
I'll let you know if I need one. I'm gonna try to reconnect the resistor on my factory one and get it going. Thanks though I'll keep you in mind for it.
1 - 6 of 6 Posts
