1 - 3 of 3 Posts
I did not fully secure my gas cap now this damn light sits there making me feel guilty as sin. been for a few days now car has 23000 miles and no problems runs great, Dealer said will go away but WHEN. A few starts and stops they said what is a few?. Seems I have done more than a few. The only thing I did was to install the dash gages turbo amp and oil heat no problems and they work fine. Any ideas. Thank you.
another way to reset the CE light...
disconnect the negative from the battery....depress the brake pedal....wait a few minutes and then reconnect ...turn car on let it idle until fan comes on then turn off....after that go about driving like you normally do as the ecu will relearn the way you drive:)
1 - 3 of 3 Posts
