1 - 5 of 5 Posts
I need help anybody has this issue before? Idle will drop to 200, even if I already drive for 10miles, when I put the to ignition and accessories, the left fan will gonna run buy it self even. The engine was still off, help help me pls
What are the codes. I believe one fan runs in accessory on position if the engine temp is up
Codes. Check engine light, uphill assist , abs, traction control, flashing cruise control plus the rpm is dropping down every time I’m putting it to neutral
Codes.
You already said that. What are the codes?
If you just want me to take stabs in the dark I can list things all day long.
1 - 5 of 5 Posts
