I would consider after getting this fixed sticking with factory oil and shorter 3k mile oil changes and having frequent used oil analysis done to see if there is a problem.
The oil should not be breaking down enough to plug passages in 6 or so thousand miles unless it's frequently run low, over heated, or contaminated.
If it is plugging passage ways that control valve timing then there is the possibility it's plugged or blocked more and you could potentially smoke a bearing. I would absolutely get this addressed asap if it is indeed the oil.
There is also the off chance of a faulty cam position sensor or something. I vaguely recall seeing something about a failing one causing a similar issue. That is what I would attack first. It's likely cheaper than other possibilities.
