1 - 10 of 10 Posts
I have a 2006 WRX with about 114k on it. After driving it for about 45 mins I got the check engine light and the cruise light started blinking. I looked it up on my accesport and I got the error code 'P0021' It says "'A' camshaft position - timing over - advanced or System performance (Bank 2)"
I have no idea what this means. Any help would be appreciated, Thanks
- Alex
List all the mods you have. It may be a phantom misfire code from a lightened flywheel.
Sounds like your timing belt slipped, but how your engine wouldn't be destroyed is beyond me.
I reset my ECU using my AP and it hasn't came up again. I'll give it a little and we will see what happens.
Could have been a slight problem with the AVCS.
Has the timing belt been replaced yet?
Discussion Starter #8
I believe so, around 100k. I bought it used with 106k and that was the first thing I checked. I looked at it and it seemed fine.
The Fruit
If you can, verify that the timing belt has been changed. What oil are you using?
1 - 10 of 10 Posts
