1 - 4 of 4 Posts
I am a frequent viewer of the show "Tuner Transformation".
On the show they have talked about (if I heard right) a CG clip. It tightens the lower part of the seat belt while leaving the shoulder strap to work as normal.
Apparently this clip is a poor mans seat belt harness for taking twisties.
Any idea where I can find one, or if I am even calling it by it's correct name?
Discussion Starter #2
CG LOCK
I found my own answer. It's called a CG Lock. Sells for $39. There are previous posts about this. Thanks!
Found a cheap solution.
I raided my daughters old car seat that we don't need but have in storage for some reason.
You can use the metal clip, but the two dark plastic clips stitched on our "Century" car seat work just as well and are nearly invisible in my dark interior. They look really nice. If you know anyone with an un-used car seat you might want to do it this way.
To follow-up...I use two clips. One on drivers and one on passengers.
1 - 4 of 4 Posts
