i just got back and the CEL code is P0245, it said turbo wastegate solenoid A low... i just installed the greddy profec b spec 2 and it has to be with that, the way i went to install it went i took the stock solenoid completely out, then put in the greddy one, i ran the hose from the turbo with the little brass pellet restrictor to the NO slot on the solenoid, and ran the wastegate actuator to the COM. did i do this right or should they be opposite, any suggestions on how to fix it?
