CEL - No codes- "no powertrain DTS or freeze frame data is presently stored"
Hello,
I have been getting an engine light randomly either after gas fill-ups or random. When I set up the scanner it indicates that "no powertrain DTS or freeze frame data is presently stored" I can't pull any codes due to no "ABS IS SUPPORTED" when I press the DTC on the scanner(to pull the codes?).
Tried 2 different INNOVA scanners and a Subaru scanner, but both cannot pull any codes when the CEL comes on, it keeps showing "no powertrain DTS or freeze frama data is presently stored" and won't allow me to see anything else.
I'm not 100% sure if the car is chipped, but I'm wondering if there are no codes being displayed due to the ECU being chipped. Does a tuner need to remove the chip in order to see the codes? Before I got this error, codes would show normally, got a code during winter for MAF sensor, so I'm confused as to why it's not saving codes.
I'm just worried that if I get another CEL for something different, it won't show any code error. CEL hasn't come back on for some time now after resetting, but it's really random.
Has anyone got this before? Please advise if you have and what you did to solve it, thanks!
Hello,
