1 - 3 of 3 Posts
Installed a TurboXS topmount and now 1 weeek later I keep getting code 1507. I know it's idle control malfunction. All connections at the throttle body are good. Any ideas?
Thats interesting...I just had that same code pop up this weekend after my car was sitting a couple days. I only have IC hoses and a reflash...I reset the ECU, and started it up a couple times to see if it could set the idle properly, but it kept going into some sort of limp mode. So I was driving to a dealership to get a diag. done and figure out what was up, and it started to run smoothly after it warmed up...so I stopped, cleared the CEL, and restarted the car and it hasn't come back since. I'll have to burp the coolant system just to check...but could it be a sensor is starting to go?
1 - 3 of 3 Posts
