1 - 2 of 2 Posts
So I read that the catless uppipe should be done for the reason of the cat breaking up and flying into the impeller...this is always bad BUT I hear some say no tune is needed and others say you need one. I also see that just putting a resistor in somewhere on the 02 line to keep the CEL off with the catless is fine.
I need to know IF I need a tune or not?
Thanks
~Gold
The only "tuning" you'd need to do is disable the DTC (if you choose not to use a resistor).
1 - 2 of 2 Posts
