1 - 6 of 6 Posts
you know that little panel that the license plate mounts to? well its kinda ugly when there is no plate there.. so i built my own little cover out of carbon fiber! it looks pretty good and when i get my camera back ill take a quick pic... anyways i made it and i dont really want to drill holes so im wondering how to mount it there
Matt
I'm assuming your talking about the front plate?
That 3m tape might work if its not very heavy.
....lol the tape probably weighs more its like a millimeter thick carbon plate
Matt
Yeah it will probably hold then only issue is that since I'm guess its flat and the tape is thick you'll have a slight gap.
pics!!!!!
Before /\
After /\
i actually found one of those aluminum plates that has like WRX etched into it under my spare ...kinda weird ehh... anyways so i cleaned it up and sanded my carbon plate down to size. then used double sided tape to stick the carbon plate to the aluminum plate then i used the aluminum to template the holes, drillied the holes, then bought a couple of sheet metal trim screws, so i filled the stock holes with a little dab of super glue, then stuck the plate/carbon assembly to the bumper with some double sided tape, then screwed it into place, it is ultra solid and personally i think it looks good.
Matt
1 - 6 of 6 Posts
