So recently I did some work on my car to install a new Td04 since the other went and I noticed my DAM was at 12 and I could hit peak boost at 3rd gear. I was only getting 6psi on the Stage 2 OTS Map from my Cobb AP. I haven't been experiencing knocks at all.
So questions:
1. Does boost leaks cause Low DAM?
2. If it is a boost leak where are the most common areas that I should look around?
3. OR is my car in some type of "limp mode."
Mods:
COBB SRI
INVIDIA CATLESS DP TO OEM CATBACK
WALBRO 255
CATLESS UP PIPE
STAGE 2 93 OCT OTS MAP
DUAL OIL CATCHCAN
So questions:
Mods:
COBB SRI
WALBRO 255
CATLESS UP PIPE
DUAL OIL CATCHCAN
