1 - 11 of 11 Posts
my cam seal is leaking AGAIN! i got it fixed 3 weeks ago, but i just dont understand why this keeps happening, maybe someone can educate me?
its actully starting to become rediculous..........
I just want to be educated on why the cam seal leaks, thank you.
EDIT: i think this happened when yesturday, i was going on it, and it was hitting boost around 4300rpms i heard a POP noise on the driver side where the cam is...........
its so wierd....and i have a 4500rpm lag :/
EvilCerealBoX said:
cam leak? i had a valve cover gasket leak but a cam leak? sorry i don't understand
ya ok imagine your looknig at your cam, the under it if you feel theres like this little area that goes in like a little square, its leaking from there cause the cam, but if it was the valve cover it leaks behind it, see what im kinda saying?
Moderating U!
Pictures would help. Thanks.
i dont have a camera but heres a pic of a ej20 and where its leaking....the circle is where it is leaking and under it not on top
Moderating U!
So its leaking inside of the cover, or behind it? I say bring it to a different shop and have them fix it. Most shops will give you somehting like a 30 day warranty on their work. You should call them back and let them know it is leaking again.
Discussion Starter #8
it was at the dealership and i have a 12 month warranty on it, so their gonna fix it, i mean it wasnt leaking for liek 2 weeks then friday i was on the fwy doing 65 some lady slams her brakes , she was like on crack or something, and then i slammed my brakes i check for any people , i did a fish tail to the left lane and caught it and passed her, then later on that night i was going on it a little then i hear a pop noise, i check my cams but it wasnt leaking maybe it didnt happen suddenly, but i dunno what it could be........oh ya and yesturday my friend gate closed on my car, ya im going to post pics tommorow on the right side of my car :/ its horrible
Moderating U!
So it isn't actuall leaking oil? And you are blaming a cam seal on a loud pop?
Have you noticed a decrease in boost since the pop. I have read that a lot of times when people hear a popping sound, it is one of the intercooler hoses coming off.
If you had a cam leak or something to that extent, there would be oil everywhere, either inside the cover or outside of the cover.
Discussion Starter #11
no i mean i checked it but not when it popped, and if my ic hose came off i would have had to fix it, i been driving it for 500miles and getting on it, still good
1 - 11 of 11 Posts
