1 - 2 of 2 Posts
I'm looking to mount a button (I/C sprayer) on one of the blanks to the left-side of the steering wheel.
I presume I'll need to remove the dashboard trim to do this, and also run a wire through the firewall somehow.
Can anyone point me to a tutorial or guide on removing the trim so I can get to the blank?
Thanks,
Lee
2 metal screws and a plastic pop- it on the left side. Pull hard without breaking the plastic panel. disconnect harnesses and there you go. Grommet is behind brake or clutch pedal behind the firewall material. good luck:)
1 - 2 of 2 Posts
