1 - 4 of 4 Posts
Hey everyone, recently my motor blow on my 2011 WRX. I took it to a shop to get it built. Just wondering how much hp and torque I should be getting with the following upgrades.
-Bore/Hone, Deck Block, Pressure
test, Deck surface, Replace Valve
seals, Valve Grind
-Mahle MS Piston Set Subaru 2.5L
99.75mm Bore 79mm Stroke
130.4mm Rod 23mm Pin -22cc 8.5
CR Set of 4
-Manley Performance Pricing
Group: Manley SC H Beam Rod
-Subaru OEM Forged Salt Bath
Nitrated Crankshaft
-Killer B Ultimate Oil Pickup
-Crawford V3 AOS
-Exedy Stage 1 Clutch
-Invidia Catted Downpipe
-Killer B Holy Header
-Killer B Up Pipe
-Nameless Catback Exhaust
-Cobb Intake
-Pro Tune
Æternum
Consult your tuner. They should be able to provide the information you seek.
Somewhere in the realm of 270 to 320whp depending on tuner, dyno, and ambient conditions.
Sent from my SM-G960U using Tapatalk
  • Like
Reactions: Kadoo101
Æternum
Wait. You don't have any fuel system mods listed. OEM injectors will definitely not provide the fueling needed to support those mods. A larger TMIC will also be a significant improvement.
Thanks for you reply. I'll ask my mechanic about the fuel system . As for a larger TMIC, it'll have to wait until I can afford that
1 - 4 of 4 Posts
