1 - 7 of 7 Posts
Should i use special non detergent oil for an engine rebuild?/Special Break in Oil for the engine rebuild? or just use regular 5w/30 oil (2013 WRX Rebuild)
Sent from my SM-G935T using Tapatalk
Super Moderator
What did the builder tell you to use? Is it just a stock rebuild or modified?
Discussion Starter · #3 ·
Stock rebuild with some built ons. and Any oil i want but that non detergent would be great/ something high in zinc
Super Moderator
Most companies have gone away from using special break in oils. The only specific "break in" oil I've ever seen was by Lucas and it was a single grade oil and not a multiweight. Where heavier weight break in oils really show their stuff is in built engines where gaps are larger to account for excess heat and pressures from high strung engines.
My engine guy and I talked about a great many things while he changed my 258 i6 into a 4.6 stroker. One thing he was very adamant about was breaking in with conventional oil. He brought it up to me several times over the 3 months that I was visiting the shop. Not sure if it is the same for these boxer engines but the man does build $20,000 race motors, and I am sure he knows more about it than most of us.
Discussion Starter · #6 ·
the guys whos building mine said a 5w-40 in high zinc was the way to go and he builds 700whp&up Subies
Super Moderator
Well, use what the builder recommends. He knows his builds. High zinc oil typically is more sought after for flat tappet cams. I don't believe we have them so I'm sure you'll be fine either way but I would advise you to heed the builders recommendation.
1 - 7 of 7 Posts
