1 - 4 of 4 Posts
Ever since I installed my perrin shift stoppers I've noticed with the clutch down while moving when I move the stick around from first to second the engine makes a sound kind if like turbo winding down I don't know if that's normal or something's up I've noticed shifting from 1st to 2md is really sticky like the shifter doesn't want to go all the way
Discussion Starter · #3 ·
Why is it the noise is only made when I move the shifter in between gears and the clutch is down
Water.....sometimes waves
Well, I take that back. I do not know if there are any "sensors" on the clutch or transmission which may make the engine do something as gears are selected. I was thinking purely mechanical connections.
Either way, it should have nothing to do with your shift stop stuff. I'd be taking that off and see if it still does it in stock configuration.
1 - 4 of 4 Posts
