1 - 7 of 7 Posts
Okay so upgrading brakes seems like something that wouldn't have a downside but I've been wrong before. that being said i've seen some brake kits that are pretty expensive so i was curious if anyone knows of any decent calipers that i can install on stock rotors. clearance issues shouldn't be a problem since i have 18in wheels with a +40mm offset. oh yeah its a 2017 wrx almost forgot that part.
But why ?
The stock Wrx brakes are really good with a pad like the stoptech streets as I have the same caliper on my legacy GT.
Replace your lines , fluid and pads first.
Discussion Starter · #4 ·
honestly this is gonna sound dumb but u have TSW Nurburgring wheels and the stock brakes just look so wimpy. If i can have the look of big brakes as well as the performance I'd do it.
Æternum
The brake rotor diameter on the new WRX is not all that small. The diameter is 12.4" if my memory serves me correctly (it didn't) -- this means they aren't much different in diameter from the outgoing STI Brembos.
I'd advise you to consider the option of pads and fluid for performance. For the non-performance related concerns, sell the wheels for a smaller diameter option. The performance will be better with the smaller diameter and the cost will be less.
Consider all the pain this will cause you over the years -- Big custom brake kits require expensive custom pads and rotors. Big diameter wheels require larger lower-profile tires that are more expensive.
Moral of the story -- don't be an idiot for street cred.
Super Moderator
Pads, rotors, fluid, brake lines. All you should need. Big brake kits are stupid expensive to own
Sent from my SM-G955U using Tapatalk
If I were to upgrade calipers and rotors I would go with AP Racing calipers minimum, and DBA 5000 rotors. But I wouldn't spend that kind of money unless I had plenty of it burning a hole in my pocket and was having problems with brake fade on the track.
1 - 7 of 7 Posts
