1 - 2 of 2 Posts
I am installing a TurboXS turboback exhaust with the high flow cat and I'm planning on installing Prodrive springs in the future. Will I have problems with scraping the cat and possibly damaging it?
Also, will the Prodrive springs cause the stock struts to wear out faster?
Do you mean scraping the cat on the ground?! If so, then there's no way that's going to happen. The cat on the TXS exhaust really isn't any lower than the stock one. And even if you were to bottom out your suspension with the prodrive springs, you still wouldn't scrape. Also, the prodrives really don't lower the car much. As far as drop goes, all it did for my wagon was make the front fender gap the same as the rear.
As far as the struts go, I do believe they wear out the stock struts sooner. I've read 10K miles, but I really don't know. I've had mine for only 4K miles or so.
-Lyle
1 - 2 of 2 Posts
