that might be pushin it a bit with the stock turbo. id turn it back a notch to 17-18I just ordered a Cobb turboback erxhaust, Cobb up-pipe, Prodrive cold air intake, and i was thinking of ordering a new fuel pump for a 2007 WRX Does anyone know what a safe boost would be? I was told 19-20 by AMS.
noWould I need the new fuel pump?
if you dont have em with those mods your going to be hurtinWhat EM are you useing. none I bet!!!
What EM do you recommend?if you dont have em with those mods your going to be hurtin
cobbs accesport is a widely used em. not too expensive but still provides a number of reliable maps (if tuned correctly)What EM do you recommend?
Ill let you know A.S.A.P.I would like to know before hand what they are using to tune the car. With enginuity you could see 18.5 pounds of boost with a good tune. Those numbers are optimistic though and would require a carfull eye to make sure the car is alright in those boost levels.
I was thinking of just going that route but im not to sure yet. Thats why i need some opinions.cobbs accesport is a widely used em. not too expensive but still provides a number of reliable maps (if tuned correctly)
I'll keep that in mind.Get whatever EM they like to use to tune. They should have already specified this. It they are thinking of using an MBC, run away.
+1Get whatever EM they like to use to tune. They should have already specified this. It they are thinking of using an MBC, run away.
