1 - 3 of 3 Posts
I have an 02 WRX with TBE, Up pipe, Samco Hoses, Silencer removal with Perrin filter. Today I was driving around and wanted to see what psi I would hit in 4th gear. The boost gauge started to climb to 14-15 psi then dropped to 10-11 psi and kept pulsating between them throughout the rpm band. 5th gear was doing the same thing. 3rd gear was only hitting around 12 psi. Any ideas what could be causing this problem.
Check your boost hoses and maybe try resetting ur ecu. You dont have a 3/16th mod done to ur car..do u?
No 3/16th mod done. I guess i will have to check everything out later. Damn I hate this car. I have had more things wrong with it. Guess back to stock and sell it.
1 - 3 of 3 Posts
