1 - 6 of 6 Posts
hi i got a 02 wrx (bugeye) and just got my boost gauge up and im only reading 10.5/11 psi of boost is this normal considering i got a mbc was on there with he previous owner i thought 02 wrx come stock with around 13 psi of boost? car still puls hard and goes good
mods:
mbc
cold air intake
3" tbe exhaust system
lightend fly wheel
heavey duty clutch
i dont have a tune so please dont bring tuning in to this i know i need it! but at the moment i cant get it
thankss :)
So what exactly is the problem? If you want 13 psi then adjust the MBC to hit 13psi. Obviously the car's factory boost control system has been tampered with.
I could could see confusion if the car was stock. But your car has been modified,specifically the boost control system.
just abit confused
The mbc is just that... A manually adjustable boost controller. You adjust it to the desired boost level, so if you want 13lbs of boost, adjust it to 13 lbs
1 - 6 of 6 Posts
