1 - 2 of 2 Posts
Ive got an 02 wrx and was wondering what i connect the wire on the gauge to to light the thing and also where can i run the line through to get to the motor? thanks
ok..first..u can split into anypower wire like the cigarette lighter socket
u can run ur wires through a hole.. if u look right between ur brake and ur clutch and look straight back.. there should be a rubber tye of oppening..if u push the suff through it,u can use that..u may have to slice oen the grommet, but it should already have a slit!!!
1 - 2 of 2 Posts
