For what it's worth, the turbo can't spool up "too fast".. whatever the scenario, you want the turbo to hit boost threshold as quickly as physically possible (assuming you're wide open throttle). There is nothing that can happen or be done to make it spool faster (aside from things like anti-lag, nitrous, etc).
Also, boost creep is a condition where as the engine moves more air the wastegate begins to be unable to bypass enough air past the turbine to control boost anymore. This happens in the very upper RPM range and is characterized by boost pressure gradually increasing towards redline in spite of low WGDC values. Pretty much the opposite of what you're describing.
It would help to know what kind of car you drive, and if you have hit boost cut (check engine light on?). I have a feeling you're interpreting the data incorrectly, but like McBill said, a clean data log would help to see what's going on and if there is indeed a problem or not.
