1 - 6 of 6 Posts
See the video below to see how badly the stock BPV leaks! We were able to pick up 15 hp and 9 tq from switching to our piece.
Link to buy: HERE
This high performance recirculating bypass valve is precision machined out of aircraft grade billet aluminum. It features an internal brass piston design and is pressure tested to withstand up to 75psi, allowing it to compliment even the most aggressive turbo builds. Spring pre-load determines the pressure differential required across the piston before the BOV opens and releases the pressurized intake charge. Designed to be a replacement for the OEM bypass valve and is available in 4 different colors.
-Larger cross section compared to stock
-100% recirculating
-Higher flow
-Pressure tested to 75 PSI
-Easy install
-No need for re-tune
Installation is simple and all mounting hardware is included.
Discussion Starter · #2 ·
Get rid of that leaky BPV, Upgrade to a Boomba Racing BPV!
Discussion Starter · #3 ·
All colors are in stock! Just produced a fresh batch for the WRX!
Discussion Starter · #4 ·
Are there any questions about these?
Discussion Starter · #5 ·
It doesn't "add horsepower" as many believe that we claim. It rather "unlocks" power that was previously lost due to the factory valve leaking.
Discussion Starter · #6 ·
In stock with a fresh batch!
1 - 6 of 6 Posts
