1 - 5 of 5 Posts
I have a 2005 wrx that smokes blue. It has a new pcv valve and the turbo leaks no oil what would cause this. If you idle it for long periods of time it will blow pretty good plums of smoke and will start to go away as it gets hot but doesn't leave completely. Has synthetic oil
Æternum
Might be turbo seals, might be piston rings.
Compression and Leakdown test. If good, suspect turbo.
Sent from my SM-G960U using Tapatalk
I'm looking into the compression test for sure. There's no blow by or smoke out the oil cap. Took hoses off the turbo and is all dry no shaft play(vf29 turbo) down pipe is dry to.
1 - 5 of 5 Posts
