1 - 5 of 5 Posts
I installed the Blitz FMIC a couple weeks ago but I can hear the i/c pipe vibrating against something underneath the car at idle. I am pretty sure the problem is that I did not attach the bracket on the pipe to the tranny. I couldn't figure a way to make it fit and thought about bending the bracket but was afraid it might break off. What did you guys with the Blitz do with that bracket?
The bracket doesn't work because it is designed for the 6 speed gearbox, not the 5 speed. You'll have to modify to make it work. I simply extended it with a piece of metal and attached to the trans at one of the bolts that hold the trans halves together. Works like a charm.
1 - 5 of 5 Posts
