1 - 14 of 14 Posts
My A/C was cycling on and off, about every 8 seconds. Not really cooling off the car on 88 degree days. My mechanic pal says it justs needs more R-134. So we hook up a can, with the A/C running on full blast, and it seems to fill normally. So I take it for a drive, and now it doesn't work at all!!! :mad: The compressor makes a double-clunk noise every few seconds; no cool air. Well, I get it home and figure I'll just make an appointment with the dealer. Then I get the idea to just let the car cool down a few hours, and try it again. To hedge my bet, I disconnect the battery to reset everything. Voila, 5 hours later it's working fine. What gives??
The A/C is programmed to turn off momentarily during hard acceleration. I don't suppose this is a contributing factor??
Nah, it always cycled on/off when idling, driving normally, or tearing it up. I'll find out more when I drive it next. Thanks for the input, Dudes.
PlatinumWRX said:
Probably an intermitant connection on the compressor relay. Check all your relays, one might be bad.
-Jim
Hmm, that's a thought. A 12-month-old car with a bad relay? :( I'll certainly look into it. Thanks!
A bad relay from whomever Subaru gets them from shouldn't be surprising given the number that are most assuredly made. Nobody can produce a good product 100% of the time, physics won't let you do that!;)
I'm kinda having the same deal. My AC doesn't seem to get very cold anytime. At first I thought that having all these windows made it hard to keep it cool. But I tinted the windows and the AC still doesn't cool off very well.
Should I take it in to the dealership and have them check the levels and connections? Or are there others with the same cool, not COLD AC?
Discussion Starter #8
"Cool--not cold" is the rule with newer cars, it seems. So I called my friendly Subaru dealer to get a quote for the a/c relay. They want $40 for the frigging little thing!! It's a pissy Radio Shack part that should cost $5 MAX. *big sigh* ....I guess we shouldn't be surprised at anything coming from car dealers anymore. Anyway, I explained to the guy that it might help them avoid a serious warranty job on my car, if they just give me the relay. Doesn't care. Naturally. :rolleyes:
Can anyone help me source this bugger?
manufacturer is Denso
PN: 156700-1020
Discussion Starter #10
PlatinumWRX said:
JohnZim,
Are you sure that's the problem?
-Jim
Not at all. It's only a possibility that makes sense. Another possibility: Is it possible to overcharge the a/c system? The a/c compressor has been behaving very strangely since we put in the can of R-134. Makes occasional thumping sounds and cuts out. ???
Nice naked rear, btw :)
Actually I have a similar problem, I have had no complaints when it comes to my a/c cooling, but ive been noticing that it seems like sometimes it cycles on and off during acceleration...
Discussion Starter #12
That's by design, so the engine has less parasitic load on it during WOT, and puts more ponies on the pavement. Mine does that on/off behavior during normal driving. Starting to wonder about the Throttle Position Sensor. Any known faults with these, Guys?
It's worth getting checked out, but the TPS would cause A LOT of other problems if it was malfunctioning!
-Jim
Discussion Starter #14 (Edited)
I noticed in the Fuse Box next to the battery, that the "Sub Fan 2" relay is exactly the same as the A/C relay. So I went and swapped these identical relays, and the same problem is occuring. That eliminates the Fuse Box relay from consideration as the culprit. One last question: Is it possible to overcharge the a/c system with R-134?
1 - 14 of 14 Posts
