1 - 20 of 23 Posts
If your car is tinted, you may feel that the reverse lighting seems a bit weak. For ~$40 / 10 minutes work, you can replace your lights with brighter LEDs.
Tools/parts needed (also replaced dome/map lights):
2 x 7440-W18-T (SuperBrightLEDs) - your bulb may be different
Knife / Flathead Screwdriver
Pull two push-pins out on each side:
Pull back the liner and disconnect the power:
Remove reverse light bulb (bulb closest to you on top) and replace it with LED:
Taillight:
Before/After:
NOTE: The camera does not do the difference justice.
Sinister said:
I want outside pics!!
I took before shots last night. Have to wait until it's dark for after...
I think there were halogen reverse lamps available at one point also. I wonder if the LEDs are brighter than those. I think the cost was comparable but I have not seen the halogens around in a while. Either way this is a great idea, there is no reason not to have as bright a backup lamp as possible, it's great safety.
Interesting. I'd be curious to see a side-by-side comparison...
The Fruit
technically led's dont "throw" light like a filament or arc source will.. they're just more intense. That said however.. there is power in numbers. Where one filament in a bulb has a certain brightness.. add 6 or 8 led's and now we have some comparable brightness as well as better light tone.
Matt where are those night pics??? LOL
My single LED flashlight puts out 200 lumens. It's not just power in numbers.
The Fruit
well better reflectors and technology help.. the new super high intensity led's are giving bulbs a good hard run for their money. Personally I'm excited to see more led lighting solutions. Imagine whole cities using long life low voltage lighting? .. one word.. awesome :D
Discussion Starter #11
Sinister said:
It's night time... I'm Waiting.... ;)
Updated
As I said there, the pictures do not do the difference justice.
Definitely cooler and they do look more intense too (is that your gardenia?). Thanks for the tip.
Discussion Starter #13
It's not quite as bright as I thought it would be, but the difference is significant, especially through my rear window (which is tinted).
As for the plant, that's an Endless Summer Hydrangea
I wish summer really was endless... Sigh.... I miss Patrick Swayze...
Discussion Starter #17
SD_GR said:
Aha, thanks! Very pretty, I'll look into them.
Completely OT, but they can be blue/pink depending on the alkalinity of the soil.
Discussion Starter #18
rage-wrx said:
Looking good Matt.
In case you're interested in doing this, you have different bulbs, I believe. I have two extra, and I went to install them on a friends '08 sedan this evening, and the OE on his car were smaller...
YES! I had some in my 07 taillights I was going to put in the 08 (just oe regular bulbs tho) and they were different!
1 - 20 of 23 Posts
