1 - 6 of 6 Posts
Choose your spring based on the strut you intend to use.
RCE Yellows are excellent, but any lowering spring is going to blow your stock struts. In fact, I consider the stock struts to already be worn out by ~60k-90k miles, so if you've got more miles than that on the OEM struts it's already time to replace them regardless..
sale-qggu3-27694 said:
how about using my stock struts ?
As MainFrame said, struts are a wear item, and on an '02, if they haven't been replaced already, they likely should be.
With OE/GR-2 struts, I'd recommend the following:
STI takeoffs
STI Pinks
Prodrive Blues
Mach V
Swift
Epic Engineering
1 - 6 of 6 Posts
