1 - 11 of 11 Posts
Have I think two bent valves and I want to see what you guys have spent to do a valve job to see if its worth it to keep the car and do the repair or just sell it and take a loss. If I did sell the car what could I get for an 02 wrx 97k miles 5spd rebuilt 5k ago, tein coilovers, blow off valve and strut bar?
Thanks in advance
Curt
Off the top of my head, I would expect around $1100 to R&R the engine, maybe $300 to R&R the heads, another $400 for the valve job, plus parts, new headstuds, etc. So you're looking at about $2000, give or take a few hundred.
KBB lists your car value at $7,931 if it's in "good" condition. Mods don't add to the value.. if anything they should detract from the value of the car.
I completely agree and completely regret buying this car. Ill be doing all the work myself so I just need prices on parts. With bent valves ill be luck to see 5 or so than.
Look around for a known good used engine and consider that too, it might save money (if it's a good motor, that is).
Pro Manscaper
Just wondering, what makes you think you have bent valves? Timing belt go while driving?
Why don't you get a leakdown/compression test to confirm there is an issue?
Discussion Starter #7
Motor ticks like no other and only after something happened with the timing while messing with it after doing a trans rebuild. Car started and made some whack noises, checked the timing but when I loosened it it slipped and didn't realize when putting it back together. Big mistake. Where could I find a used engine and how much?
Discussion Starter #9
Of course, I was just asking more of a ball park number, like the average most pay for a used engine. Ill have to do some researching
I was going to sell my spare ej205 for $1000+ shipping.. but after I pulled it I noticed that the timing cover was damaged, and I can see one of the cam gears is broken and the belt is shoved back. I still need to pull the cover off and check to see if the belt jumped.. if not I'll probably do a compression test before I go ahead and sell it. Hopefully it doesn't have bent valves too.
1 - 11 of 11 Posts
