1 - 12 of 12 Posts
I just purchased my first WRX. It is a bone stock 2004 with 110,000 miles. Before I increase the HP I would like to get the brakes and suspension up to snuff. I will be starting with the brakes. I would like to be able to use my OEM 16" wheels(which are currently being fitted with winter tires) for the Cleveland winters. I will be putting 17" wheels on in the spring(I am thinking Sparcos). I need to upgrade the brakes as much as possible while still keeping overall diameter inside OEM 16" wheel requirements. I won't be going overboard with engine mods. Eventually just a Cobb stage 2 maybe a little more. Any good ideas. Also any starting suspension mods. I will be driving this car 25 miles each way to work so I don't need it to be to ridiculous, just a little more lively. I don't plan on doing any real racing I would just like the car to be something I can live with everyday and have fun taking the back roads home from work.
Upgraded pads, rotors, stainless lines and fluid and a master cylinder brace will yield great results. As for suspension a good spring/strut combo and some sway bars along with a number of bushings will be a good start. For specific brands and products do some google searching through the forums.
Sin- was it a complete p.i.t.a? I've been wanting to upgrade but I've heard mixed reviews about the install. The fronts are direct bolt ons while the back require some mods, am I right? :confused1
The fronts are a direct swap. Rotors, Pads, Calipers. Even my SS Brake lines worked just fine.
The Rears are a pain because the ebrake is different between the STi and WRX. BUT... DBA developed a rear rotor that works with the WRX ebrake, and the brembo calipers. So... as long as you use that rotor, it's an easy swap.
I'd just make sure you get a couple pairs of the DBA rotors... who knows how much demand there is for them, and how long they'll make them.
Æternum
Google "H6 rear rotor upgrade". It's the best bang-for-your-buck brake mod for the 2002-2005 wrx. Basically you get upgraded ( from 10.3" to 11.4") rear rotors from the older Legacy GT for <200 bucks. I have this done with my BBK fronts.
Front: ~$600 2006-07 Subaru "Group-N" 4-Pots (you will need a 5 mm spacer if you plan to use the stock 16" wheels)
Rear: ~$250 Legacy H6 rotors
Pads: your preference
Tires: your preference
-Shadow
1 - 12 of 12 Posts
