· Registered
My original metal ring (baffle plate) fell off the axle while I removed rear passenger knuckle for wheel bearing replacement. I figure this part name looking at diagram from online dealer and order it.
Question is, how it should be installed correctly on axle? Just push it on the axle until it cant go no more? Or other procedure? I understand it stops the knuckle to slide further on the axle and also play the roll of the
protector from particles flying into the hub?? I am not sure on it.
Thanks guys,
Alex
Here few pictures:
p.s. Passenger side is stayed on place so I reinstall the hub with no issue, but the one that fell off on another picture. I was trying to push it on axle similar to how it sits on another side but it does not stay tight on the outer end of the axle.
