1 - 7 of 7 Posts
Well I finally got my boost guage installed today. I hooked it all up, I may still need to tighten down some of the connections.
However I got it hooked up and when at idle it was reading a negative pressure. I know that is the way it is supposed to be but what it the normal range? How far neagative should it be?
Then I noticed that when I was driving and pushed the car in 2nd and 3rd that the boost went all the way up to about 14 or 15 PSI.... But I have not done anything to my car. It is totally stock and I thought it was only supposed to run at like 9PSI max..
I don't know what is wrong and how I can fix this problem. I have the boost guage "T'ed" into the line that comes out of the BOV....
What should I do?
Relax: It looks like your gauge is reading correctly. Maximum stock boost in 1st gear ONLY is around 9 psi. Max for 2nd about 12.5 psi, and max for 3-5 around 14-14.5 psi. I too just installed an Autometer gauge, and it works fine.
Humm ...
Weird ... in 3rd and 4th when WOT I get 15psi but then it drops down to 13psi and stays there?
The smaller turbos seem to run outta breath at the higher rpms also, so it is typical to see a spike (or peak) and fade of boost at the higher rpm ranges.
F
1 - 7 of 7 Posts
