1 - 20 of 32 Posts
The first step in my project. My best amp finally arrived. McIntosh MC427. Here are some pics. Spec is 100Wrms x 2 to run my front stage. This amp is pretty much MINT and I got it for $325 on ebay. Most beautiful thing I've ever laid eyes on, I may just hang it on my wall instead. I had a MC440 in 2003, but it wasn't close to this condition.
The amp rack might arrive today, and I should have more pics by tonight.
SuperNova
McIntosh eh?? Kickin it old school!! Awesome amps!
I had a few Linear Power amps in my old system. My largest was the 2.2HV rated at 2.2 HP. ;) Thing had a ton of sharp heat dissipation fins and was brutal. The best amp I ever owned.
Mine was black but looked just like this
I'd cry if that McIntosh got stolen out of my car lol.
I carriage bolted my Linear powers in, so removing was a 2 person job ;)
I almost bought those LP amps a few times back in my day. I think they were $699 or $799 at least? Ya I will get insurance on my gear I guess. And I need some ideas on bolts that will be better. There will be nuts on the back side of amp rack of course.
All my other stuff came in, didnt even have time to open it:
Audio Integrations amp rack
Alpine 600Wrms sub amp
CDT Classic components with upgraded tweet
10 ft 8 gauge wire, blue and clear to match my 4 gauge
stinger dual distribution block
Tomorrow.. I lay out the 2 amps on the rack and drill 8 main mounting holes. Then I start tracking down the hard parts. Theft preventative bolts of some kind. And 1/2" spacers for the bolts to raise the amp off the rack. The wires will go behind it as mentioned earlier.
SuperNova
For bolts try "Tamper resistant Torx"
Requires a special tool but worth it.
Make sure to use Nylon Lock nuts on the bottom side or it was all for nothing.
You can buy them locally or through www.mcmaster.com
Discussion Starter #9
Lock nuts on the bottom of the tamper proof torx instead of regular nuts :thumbup:
oh i got it.. I thought it said nylon lock washers.. thats why i was confused. Ya I know about nylon lock nuts. But I dont see them often in local hardware stores..
Discussion Starter #12 (Edited)
Picked up all the special nuts and bolts I needed. I wont give away all my security bolt secrets, otherwise what is the point?
I finished drilling all my holes in the rack. The 8 tiny holes are the amp mounting holes. The 3/4" holes are for the wires and will be behind the amps. I have a choice of 1/2" spacers or 3/4" spacers once I see how the wires look.
This was my first time touching fiberglass. It has a funny smell. Reminded me of when my parents built a 30 ft. catamaran in our backyard in Ireland. I now know it must have had fiberglass portions.
Discussion Starter #13 (Edited)
Got the amps mounted tonight. They look a lot better in person. The gloss black is flawless in person, but the flash shows imperfections. My only worry is whether I will have room to fish the speaker wire and RCA's thru from under the amps. The amps are all on 1/2" spacers.
Discussion Starter #14 (Edited)
Got the amp rack done and the rear seats are back in.
Tip: Use a larger spacer than 1/2" behind your amps. I had everything installed and had to loosen the amp bolts to get the RCA pulled thru under it. 3/4" spacers would have been PERFECT.
This is by far the sweetest cleanest system I have ever had, and its all because of Audio Integrations amp rack. Without it, I would have had another sloppy install.
I tested one CDT woofer on a McIntosh channel and it worked. I turned the McIntosh gains all the way down, which is marked as "2V". Since I have 4V, I guess I should keep it minimum once the speakers are installed? The next phase is to install the CDTs in my doors tomorrow. Then I had that sub sire you can see for my JL 10W6v2. Just waiting for my Audio Integrations sub box to finish it all off..
1 - 20 of 32 Posts
