1 - 5 of 5 Posts
Hey needed some help here, I have a ATS Brembo kit for my 17 WRX premium, and I was told I need to get 36x30 rotors for the front will this setup clear my OEM 18' Wheels or don't need to upgrade/go for a different set up?
Super Moderator
You'll need to check the brembo site for specifications on the calipers. Many times the 6 pots will clear the id of the wheel however you may need a spacer to clear the back of the spokes. The only way to know is to get the dimensions of the caliper and measure.
Sent from my SM-G955U using Tapatalk
Æternum
They are 4 pot and similar to the STI (pre-2018) brakes.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Super Moderator
This is the caddy swap? My mistake I thought they were 6 pots.
You should still be able to find measurements. I don't know the clearance on the new wheels but on the GR you had to run a spacer
1 - 5 of 5 Posts
