1 - 6 of 6 Posts
I want to purchase a Dp that bolts right to my factory cat. but some of these Dp look longer than others. maybe it's just the pictures. Also is there a cat in the up pipe? 04 STi. :confused1
No, not all downpipes are the same length. For example turbo xs will bolt up to nothing! Others only eliminate the downpipe cat and bolt up before the 3rd cat, and most get rid of both the downpipe and 3rd cat and they bolt up directly to the cat-back systems.
And no, there is no cat in the STi up-pipe..
if youre looking to keep one cat, there are a couple ways you can go...
you can get the turboxs stealthback with the highflow cat - www.turboxs.com for more info
scoobysport partitions off the exhaust into the same exact sizes as the stock pieces. so basically, you can just mix and match what you want to put in there. if youre not worried about emissions or the environment, i would just say to get a complete cat-free turbo back. itll be more fun ;)
Dyno Results
Has anyone Dyno the APS 3.5 " turboback sytem witth a 4"exhaust tip, and a APS short Ram intake. If so how many HP has this given you, and lb-ft of TQ? Or does anybody know who did.
I spent a lot of time looking at shorty downpipes (ones that mate to stock 2nd cat, 3rd cat in WRX). www.daddysscp.com has almost all of them. Bosal, stromung, Hayward&Scott, and scoobysport will all mate correctly. I went with the stromung. I also bought a cat delete pipe so I can switch from catted to catless in about 20 minutes, without having to disconnect the downpipe from the turbo.
1 - 6 of 6 Posts
