1 - 9 of 9 Posts
hey, have a 08 wrx with a turbo xs cbe and have the stage 1 93 octane map loaded but keep blowing a code wen boosting 4th and 5th gear , its a check engine light trac control light and blinking cruise light the ap reads its wastegate solenoid "a" range/performance ......has anyone experienced this before?.....wat can i do to fix this prob?.... need help cant figure it out
the check engine light is for the wastegate soleniod your boosting over what the solenoid is set for for to long.. i had 02 wrx with a boost contoller intake and cbe no tune and if i boost 15psi it would do that.. correct me if im wrong
You're overboosting. Does Cobb offer a LWG map?
Robwrx117 said:
how could i fix this and keep my tune??? any ideas..
Don't go WOT in 4th or 5th
Good news, everyone!
You don't. Go to the link Rambo provided, flash the LWG version of your map and see if it fixes the issue. After that, call Cobb.
Out of curiosity are you flooring it at low RPMs in 4th or 5th? Shouldn't do that.
¯\_(ツ)_/¯
It will take you all of 5 minutes to fix this with a new map, why wouldn't you want to do that? :screwy:
1 - 9 of 9 Posts
