I had to disaasemble and reassemble my STi front struts (error on washer) and somehow I've stripped the lower portion of the strut piston bolt. It wouldn't tighten down all the way and I noticed upon closer inspection the lower portion of threads were stripped- I could lift slightly the nut w/ a pair of needle nose pliers. I couldn't get the nut off either, as it wouldn't go by the threaded section. For now I've put another nut over the top and have it tightened down. The second nut went on about 60% of the way.
Would it possible to rethread this bolt section (its smooth now)? Any ideas on how to get the nut off- not enough room for a nut splitter, don't want to torch it off for fear of damaging the STi tops.
I got the part # off of the strut and priced it at subaruparts.com- $305! I then priced the left front kit (strut AND sopring AND dust boot AND hardware)-$295. What the hell is up w/ that?
Any suggestions would be appreciated
Big Sky
Big Sky
