1 - 5 of 5 Posts
I was wondering if there are any new 6 speed transmissions that can just bolt up to my 2002 wrx? Will the STI trans bolt up? I was also wondering if maybe an older wrx sti transmission would bolt up since it would be very easy to get a used 6 speed from japan. If there are any 6 speed bolt up transmissions let me know please and the price if you know it.
The new STi will not directly fit, but to get the 6speed tranny setup will run you over $6000 I believe. I know Godspeed sells them, www.godspeed.hack.net .
As for buying a old 6 speed tranny....good luck, the older STis didn't have a 6speed tranny. You can get a nice 5speed box however....but you also have to check the final ratio since various version STis used different finals than the current 3.9 on the WRX and WRX STi.
the numbers I've seen to re-gear your WRX to STi specs about $8000 for parts (including final drive gear and a bunch of odds and ends needed to make the STi tranny "bolt up". probably another $2500 to have someone do the work. if you're going to spend that kind of money you're better off just waiting for the STi..and if you're willing to spend $10000 to upgrade your tranny you're getting into Audi S4 territory.
1 - 5 of 5 Posts
