1 - 6 of 6 Posts
Ok, so the clutch on my 2002 WRX is starting to slip, my mother (who owned it before me) has always been a little heavy on riding the clutch petal.
For me, I felt that the clutch was always a little on the soft side compared to heavier clutches I’m used to, like the dual mass setup that was on my old 190 Cosworth, 7.3L Powerstroke 6 spd, and an old Mack 8spd rock crusher i used to operate.
I’ve been reading that the preferred recommended clutch for our rides is the Exedy kit and a new flywheel. I’m not against this, and I agree that it’s better to have the clutch being the weak link to protect the transmission.
I’d prefer to have something with a bit more clamping force, but not looking to go with a puck clutch. Maybe a stronger pressure plate? While in running a stock setup currently, I might be building the motor up a bit in the future, replacing worn components with upgraded pieces. Id be open to a stage 1 setup if it’ll stiffen up the petal a bit (keeping an organic disc) and not burn up after 30K miles.
I’ve found two Exedy kits I can get, the KSB03 and the FJK1006. Which one is the preferred Exedy kit?
I’ve also read that ACT clutch kits are of a good quality, but wanted member feedback. What about ECT clutch kits? I’ve read many Amazon reviews, but what about users here?
Æternum
I'm confused. Is the vehicle stock? If so, a slipping clutch is indicative of early wear. The best replacement is an OEM replacement.
Why do you want something with "greater clamping force" if it is unnecessary?
1. Yes, vehicle is stock. I thought it was strange when I first heard that the clutch in these only last around 70-80K. I know part of it is my mother’s driving style, but geez!
2. Greater clamping force, just something I’m more used to and comfortable with.
Æternum
70-80k is a bit short, but not unheard of.
My bugeye was at 110k miles with 20k of that significantly higher than stock torque output, original clutch.
I've never gotten less than 150k miles out of a clutch, but have heard of people burning through them in 50k miles or less.
Sent from my SM-G960U using Tapatalk
I'd go OEM also. My stock clutch has 210K on it. So far, so good. I'd pay attention what fly wheel goes in, nothing lighter than stock.
1 - 6 of 6 Posts
