1 - 2 of 2 Posts
Okay so I went out and financed a 2008 wrx sedan. 3 weeks in the turbo is leaking tons of oil and coolant, the stock intercooler fins are all laid flat (wouldn’t think any air could get through), and there’s a crack in my down pipe. Mechanic said 1,700 he can get it back to stock. But then I did some research. And the vf52 swap was very attractive. So I ordered
-IHI vf52 turbo
-AVO TMIC (keeping stock Bpv)
-Rev9 Catless Downpipe
- Cobb sf intake
-Cobb turbo inlet
-Cobb AP
-TP stage 2.52 map
-mishimoto IC to TB hose
I haven’t done the swap yet, as I have a few questions.
All of these mods should bolt right on correct?
Do I need a pro tune? Or will the tp 2.52 be good enough?
What kind of HP should I expect? (Everything else is stock)
Lastly if anyone had done this swap and can recognize something I’m missing or give me some pointers, that would be greatly appreciated.
BooSTIng
Everything looks good to me. Nothing is sticking out that you may be forgetting. Torqued Performance does a pretty good job at e-tuning. Be sure to send Eric there as many datalogs as you can. Datalog the parameters he wants/needs and be prompt to send them. From what I have seen, anywhere from 2-5 revisions from him and the car should be good to go.
A protune would net better results, at the end of the day no tune beats a tune from a skilled pro tuner. Only thing I will mention is to make sure you replace all exhaust gaskets as you put the new stuff on.
1 - 2 of 2 Posts
