1 - 5 of 5 Posts
I have a 2007 wrx and when I make a turn to either direction, the car wants to turn in that direction when I start going straight again. I’m not sure what the issue is but I think it’s the cheap coil overs the previous owner put onto it
If your steering wheel does not self-center after a turn, check to make sure you're not driving an Alfa Romeo Sprint QV. If you aren't, check the caster angle on your front suspension, check the control arms, and check for wear in the bearings of the struts.
That sounds like CV joints to me.
2012 Subaru Impreza WRX Premium 5-Door 2.5L Turbocharged 5-Speed Manual
My money is on the strut bearing plates or a binding tie rod/ball joint. Is the noise heard on only one side or both?
1 - 5 of 5 Posts
