1 - 4 of 4 Posts
I would like to get optimal alignment specs for my Rex with my setup, as I think most places will just do an oem alignment, wont they?
Shes on the Eibach pro-kit, with rear camber bolts. Sits on 17.7 BBS rims with 215/45/17's.
Any thoughts?
Also, how bout specs with the Eibach drop and RE92's? Im thinking of throwing those puppies back on for a bit.
Your alignment won't change for the different wheels. Here's what I run:
Front:
-1.3 camber
0 toe
castor at whatever its at
Rear:
-1.1 camber (no camber bolts, thats how it is)
0 toe
nothing really adjustable back there except toe
I run -1.3 because that was the most the shop could get on one side, so I had them match it on the other (the other could get -1.6). Toe out in the rear of 1/16 or 1/8" wouldn't be horrible, but I decided to go with 0 for tire wear reasons.
tcc
Moderating on the run!
The settings Jay listed are pretty good- you could go a smidge lower in the rear w/ negative camber as you have camber bolts- say -0.9. To get any more agressive you should be able to articulate why and you'll need additional camber adjustment upfront.
Big Sky
1 - 4 of 4 Posts
